***Official Batman Arkham Origins Thread***
Try turning off Physx in this game, some have said it is buggy atm
It certainly improved things for me, but the Nvidia article link to earlier in the thread indicated I should be able to max the game out.
Running at the default settings and it still has the odd stutter, mostly when auto saving or gliding over the city
http://www.geforce.com/whats-new/articles/batman-arkham-origins-graphics-and-performance-guide
aaarrrgghhhhh!!!!!!!!!!!!! DEATHSTROKE IS SO ******G HARD!!!!!!!!!!!!!!!!!!!!!!!!!!
Counter > Grapnel > Attack > Attack > Grapnel > Attack > Attack > Grapnel > Attack. Will force him into the transitions and eventually beat him. I play without the block indicators as they just get in the way, but I found with Deathstroke that pressing block just as he is about to hit seemed to do the trick.
Must add I like the new "block during beatdown and resume beatdown" move, using it at the right time can result in you blocking 4 opponents while maintaining 1 beatdown; pressing T (if you have enough combo) after blocking 4 causes your aerial-ground removal to take out 5 at once, as the one being beat down is also considered a target for removal.
loaded fraps to have a quick look at fps and mostly 150 to 250 maxed settings but im only running single 24 inch monitor and no AA and the lowest ive seen so far is 80 fps and played upto the ship.
Good fun game im having fun playing it and not had any bugs yet.
Deathstroke is easy once you realise BB is a nab
Counter
Press Combo+Mouse 1 until you hit DS
Once he hits back DO NOT SPAM COUNTER - just wait for the "Counter" onscreen and press it ONCE each time it says to
I am such a tard
P.S. Once I have defeated DS, how the **** do I get out of that area???? The upper door is locked :( :(
I did manage to take him out on my 4th attempt, but yes, it's tough.
runs constant 60fps at 1440p for me fully maxed with physx on high...very happy!
Yeah, I like it too. I get highs of 115 during most situations on 1080p.
Counter
I am such a tard
I've read you need to reload the game as the door will not unlock. It seemed to work for me.
Might be a common bug then, took a while to get out as none of the doors seemed to work, watched a walkthrough vid to see where they went after the fight and realised it was bugged and also saw the console version had the extra bits in the fight. Restarted checkpoint and door worked.
Counter
I am such a tard
i was stuck too .. try to open that uper door then go back into the room .. penguin should come up on a screen .. then you will see the way out
You'll think back fondly to Deathstroke once you've fought Deadshot ;)
Honestly what bugs me is in certain places the grapple "f" symbol doesn't show up very well when aiming directly at other perches, this is most irritating in setups where you are moving around in one room though is irksome in the outside world as well.
The Deadshot fight is, boring, irksome, silly things happen which you weren't really expecting meaning a few reloads is pretty likely and then, to cap it off in my best run yet where I was about three seconds from finishing him......... game crashes.... rage quit!!!!!!!!!
or maybe the football was on, bit of both really :p
GFX settings dont save?
When i start the game its in a window then when the blabla is done gets to fullscreen.
Set everything at max and save (physx needs to restart the game). Restart and everything is at stock options again...
The GFXSettings.BatmanArkhamOrigins seems all good, even changed to read only, doesnt work.
Other then that game runs great on maxed out 8x aa
This game is an absolute joke. How have they released yet ANOTHER batman game in a broken barely playable state? Between me and a friend so far the following has happened inside about 5 hours combined usage:
1. DX11 flat out refusing to work on my friends 7950 (works fine on my 780)
2. Lost audio completely on the first smoke pellet prompt (set to headphone out restart game to restore)
3. Killer Croc vanished mid fight - restart required
4. In game map/upgrades menu will randomly not do anything, opening the map will result in nothing.
5. Stuck with cryptographic sequencer open, no way to close it, just sit tuning through radio stations - restart required.
Last but not least THE GAME BREAKING BUG!
Warning this one may contain spoliers...
Early on in the game, you collect some sim cards to triangulate the Penguins position, I did this, you find him on a ship to the far north east of the map. On this boat you fight Deathstroke, first time of asking, non of the doors would unlock after the speech from penguin - again, restart game. Once I had gotten off the boat and outside my objective didn't change.
So now my objective ALWAYS says:
">Find the Black Mask
>Find second SIM card and triangulate the penguins position"
I can't move any further with game as I've already completed this objective, so I got no markers or hints to my next objective, simply stuck mulling around the city, no known fix, reboot does nothing, return to batcave does nothing, can still go do any available side missions but will always ultimately reverting to the above. The only way to progress is to loose my 3-4 hours progress and start from scratch - no thanks.
So thanks WB Games for releasing yet another broken bag of **** to PC users.
wow im not having any problems pgi947,and im playing with a 560ti with physx turned off.im getting 60fps with v-sync on.
its strange how some people have problems and others dont.
The actual game graphically runs perfect for me, fully maxed out inc physx, just the rest of the game as absolutely riddled with bugs for me :(
I thought they may have learned a lesson after the disaster of a launch Arkham City suffered.
Have to say I've had no problems at all with mine. :)
Counter
I am such a tard
another door with the flashing exit sign above.... ;)
Just found another game breaker....
Go to the comms tower in the Burnley district, you will use remote batclaw to zipline through a window and hack a device, once the device is hacked Enigma will lock the doors and windows leaving you with only a vent to go through. Pull the vent cover off with batclaw then climb up to the vent, batman WILL NOT go through the vent, he will simply hang there giving you absolutely no way to carry on with the game without restarting it.
Can someone tell me exactly what happened in their story line after they defeated Deathstroke?
I got:
Defeat deathstroke
Taunted by peguin
get remote batclaw
use it to go up to penguins door - locked
leave the ship
Somehow giving mission objectives that are already complete.
Edit: Oh if I go back to the ship, none of the doors are now locked, including the one penguin ran off into but no one is to be found :confused:
Just got the same bug. :(
Hmmm, think I will avoid this game till a patch is out, cba dealing with those problems where you have to restart the game to pass an area, had the exact same problem with either AA or AC and ended up having to restart the game like 4 times to complete it...........
Shame :(
Shame :(
Seems to be the norm these days :(
