I'm pretty sure I tried 20x200 at 1.35v and couldn't boot into Windows. Might have something to do with the IMC though? I will try your settings when I get home. Thanks!Do you actually need that much vcore? 1.35v seems high for 3.8Ghz. My old i5 760 in my Asus P7P55D-E Pro only needed 1.285v for 4Ghz. Have you tried 20x200 at 1.35v? That would get your ram up to 1600mhz as well. Try to get the voltage lower if you can.
I know mine was a i5 760 but my settings for 4Ghz were:-
BCLK 20x200
vcore 1.285v
IMC 1.16250v (may need a tad more if running 4x sticks of ram)
CPU PLL 1.8625v
PCH 1.0875v
Just tried:Do you actually need that much vcore? 1.35v seems high for 3.8Ghz. My old i5 760 in my Asus P7P55D-E Pro only needed 1.285v for 4Ghz. Have you tried 20x200 at 1.35v? That would get your ram up to 1600mhz as well. Try to get the voltage lower if you can.
BCLK 20x200
vcore 1.285v
CPU PLL 1.8625v
PCH 1.0875v
