The "Post your pictures here" thread.
Status
Not open for further replies.
29 Jul 2011
Near Northants / MK
I'd probably buy a 50mm 1.8 as well if you really want blurred backgrounds. Assuming you're using the 18-55 atm?
Yup, the 50mm 1.8 is on my buy this. If Christmas wasn't here I'd already have it :p I definitely need to learn on how to keep the camera straight though... Then again that was the only photo. I was with others so I felt I was holding up but further on in the day I just decided screw it and took my time :)
Caporegime
13 Jan 2010
Llaneirwg
A harvest man
Harvest Man by Al4x, on Flickr
A flower stigma
Stigma by Al4x, on Flickr
edit, that was 2mm and my dof was 1mm
used a 3cm tube with canon 100mm L macro on 60D
unfortunately no ring flash and that is cropped as my lens barrel was already causing a creeping shadow
26 Mar 2007
Status
