by this Friday at least u will have itJust to throw a spanner in the works, the 280x is meant to receive a running upgrade on the GPU at some point, not sure when. Presumably it will get full directx 11.2 and trueaudio among other things.
I hope you're right.. I also hope you're wrong![]()
AMDs R9 280X might still be using the oritinal 7970 GHZ edition XT2 Tahiti GPU and replace it with Tahiti XTL next month. Apparantly the Tahiti XTL GPU was not ready for the launch and all current Radeon R9 280X graphics cards ended up with the Tahiti XT2 GPU instead. Various sources confirm that AMD will do a, so called, "running change", where there will be no announcements and no name change for the new GPU and the only way you would be able to tell which GPU is behind the R9 280X is by its BIOS version.
Of course, nothing is carved in stone as AMD can simply decide to launch a different named graphics cards with Tahiti XTL chip but currently the plan is to do a running change.
Apparently, Tahiti XTL should have a lower power consumption and thus should be easier to cool. We will surely keep an eye out and our ear close to the ground in order to spot the new GPU in November.
