Hi,
As the title suggests I am looking for some advice on what to buy as I attempt to upgrade my current rig pls. I mainly use the pc for gaming (aiming to play BF4 among others) so will be upgrading with that in mind. I hope to be able to use eyefinity with 3 monitors but if that is gonna cost a great deal more will settle for a single monitor setup.
Here is what I have at the moment:
CPU: AMD Phenom II x4 955 (Deneb 125w) stock cooler
MB: Gigabyte GA-770T-USB3
RAM:G Skill Ripjaws 4 Gb (2x2Gb) F3-12800CL7-2680 (PC3-10700)
GFX: HIS ICEQ Turbo 6950 2048MB running at 840Mhz Core 1280 Mem Clock
Power: XFX Pro 850W
Main HD: Seagate 500GB
I have recently picked up a Samsung840 pro 256GB ssd which I will install my OS on and a couple of games.
Here is what I am thinking about getting. I do plan trying to oveclock the cpu.
CPU: Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail
The cpu I choose over the i5 3370K for future proofing. I believe my current power supply is Haswell ready.
Cooler: Noctua NH-D14 Dual Radiator CPU Cooler
MB: Asus Z87-A Intel Z87 (Socket 1150) DDR3 ATX Motherboard
This was a real unknown for me I picked this board as it seemed to be a good price yet would allow me to overclock and has all the features i thought I might need.
RAM: Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9)
I choose these are they are low profile and would help with the install of the Noctua cooler, also because if I oc the cpu I dont think there would be any point getting any faster ram. However I am very open to suggestions. Also not sure if i should go for the 16 GB set instead?
GFX: HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M)
This was my first choice but after seeing the deal for the Asus Matrix (listed below) I wonder if it is worth trying to stretch to that price? Also I wasnt sure about the R9 280X?
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card
Thank you for any advice or help you can give me.
ps...Missed an 'o' in the title, sorry, dont think i can edit it
Power: XFX Pro 850W
