Where's mine?!?!
Did you order Premium as well? Did they sent you that too?
They're sending the keys out today, No I didn't get premium in the end, just the standard game with the first map pack.
Where's mine?!?!
Tried loads of drivers, all direct x fixes etc..
game still crashes after about 20 minutes or less with device hung error. Used to happen in Battlefield 3 aswell.. using a 7950 :/
It's not overheating or anything but it is very annoying can't play a full game!![]()
HKLM\system\currentcontrolset\control\graphicsdriver\
create dword "TdrLevel" with the binary value of 0.
netcode is slow with update and you nedd your ping matched to the server around 40-60ms
I had 200hours played in BF3 in 2 years.
it sucked badly. I just hate it.
If you don't like the game just move on, no need to keep bashing it.
I have the same problem. My current attempted fix is via the registry, in summary the OS beleives the card has hung when clearly it has not. You can introduce a delay greater than the 2 secons default, I believe 8 seconds is the recommended value, but I've not opted to disable it completely.
http://msdn.microsoft.com/en-us/library/windows/hardware/ff569918(v=vs.85).aspx
To disable it:
Code:HKLM\system\currentcontrolset\control\graphicsdriver\ create dword "TdrLevel" with the binary value of 0.
I'm still in testing, but so far so good. I'm on Wind 8.1 with a GTX660 (non ti).
My crash would happen randomly, getting great FPS then boom, crash to desktop with the hung message (though not full desktop, task manager able to open and then switch application to see the error).
Be interesting to see if this helps you. I'm nearly tempted to buy an AMD card.
It's a fair point though, fair enough if you don't like something then let people know your opinion.
But there's no need to spend precious time on your life repeating to people how much you don't like it, whilst reading a thread dedicated to it really, is there?
Got my BF4 key from Simplycdkeys![]()
Oh, I'm now downloading the game (paid for via UK Origin, no VPN no questionable currency good old sterling and getting 6.88MB/Sec download. 45 minutes remaining.
Those of you who ordered Premium as well from Simply please let us know if you got that key too![]()
