I was having problems with mouse input lag when gaming so I've gone back to 8. Something do to with the new DPI scaling framework in 8.1.
It's adorable that you think you can tell people not to post.
Clearly you've not really understood my post, as I was pointing out the ridiculousness of "it's not worked for me therefore it's broken".
spoffle said:In response to Easyrider, I am using Chrome and Firefox on all 3 of my windows 8.1 upgrades, I've had no software issues.
After installing windows 8.1 chrome doesn't connect to the net properly.(all over the web the issue has been reported)
Numerous BSOD restarts
Should have tried running the game in Win8 compatability mode it seems to be a fix.
easyrider certainly comes across to me as someone who generally knows what they are talking about in other threads so saying it's PEBKAC is not actually very smart. It is well documented that some people are having issues with 8.1, so if you don't have anything useful to say, do not post.
I doubt it's pebkac, but if your having problems, probably time to bite the bullet and back up data etc... and fresh install the o.s.
why did you not just go to 8.0 ?
most of the issues are none existent and no real difference from 8.0-8.1
)Win8.1 seems to have problems with browsers, I've had firefox and ie11 crashing so far.
I just d/loaded IE10 just in case this 11 gets too ****ed up by me. So far I have disabled Adblock+ (Simply because WIN8 and AV's in general don't get on well.
Also going into IE settings and turning off "Use Microsoft compatability views" has helped people, Windows 8.1 and Google don't get on apparently.
Aslo I have noticed that when running Steam, IE 11 crashes a lot, there's error messages in admin events viewer saying tcpip error, windows is throttling connections as you are too greedy, basically. I think maybe windows is having problwems organising our internet use, I have a hunch this tis the main problem with win8 and browser crashes.
Don't ask me how I know, I don't know you see. I am making an educated guess![]()
