Will the 780 play it in ultra setting's
ultra 1080 minimums of about 55 fps maxxed. to have minimums above 60 fps you need a 7990 or 690 or crossfire or sli cards.
I think if I was playing BF4 I would probably prefer the R9 290 or even a cheap R9 280X or HD7970GE card. The thing is if Mantle gives a 20% boost in framerates,then the a R9 280X or HD7970GE would be the best value for money cards for BF4. People forget that NVAPI was used in BF3 which is much less far reaching than Mantle might be,and that helped Nvidia have a decent performance boost over AMD for quite a while in BF3,even with new the latter having newer cards.
We shall soon find out how Mantel shapes up in less than three weeks though.
AMD launched their "hot card" which beat their competition at £50-£70 lower in price; Nvidia launched their "hot card" which beat their competition at £130 higher in price...see the difference?I lol at this as I remember when the gtx480 was released , NVidia got a right kicking due to the heat/noise . amd do it and everybody say "not a problem" lol
Right now go for the 780, its the cheaper of the two and the reference cooler on the 290X is not to good, with board partners coolers a little way off yet.
Maybe but I feel too much emphasis is put on fps at times and what the desired acceptable frames rates are.
A 780 averaging 90 fps or a 290X averaging 108 fps (20%) for most is never going to be noticed.
If the averages were 40 fps on a 780, then 48 on a 290X would be more desirable of course but going from what I was getting in BF4, my first call is pretty spot on.
Its not the point though. The performance boost will be more noticeable on "lower end" cards like the HD7970GE and R9 280X. Something like Mantle has the ability to push them up to the current level of much more expensive cards. Nvidia managed to hold off the HD7950 and HD7970 in BF3 for months due to the use of NVAPI by DICE,even though the first two now end up being faster in almost all games over a GTX580.
Mantle looks more far reaching than that,and if it does deliver decent enough gains,it will be people with less expensive cards who will notice the most.
So bf4 is around the corner 780gtx has had a price drop what of the two cards would oeople recommend for bf4
Just dont want to buy a 780 and when mantle comes out then wishing I had got a 290x hard choice![]()
