Fastest and most silent GPU for SFF (2slot)
16 Aug 2004
Hi,
I am currently building my new SFF PC and realized that the Asus 7970 DC2 Top doesnt fit!! Please suggest me the most silent and fastest GPU for 2 slot and 1080p gaming.
Thank you in advance
Sorry...
The case is Lian-Li PC-V355, i5-3570k, Extreme4-m, 8GB. Unfortunately I already have an Asus DC2 7970 Top which doesn't fit because of its height!! I am not looking for something faster but smaller and at least the same noise.
thx
Sorry...
thx
It uses an mATX motherboard,its not a SFF PC!!!:p
The case has 4 slots so surely the Asus is fine:
http://uk.hardware.info/news/28114/lian-li-introducing-two-new-compact-chassis
Edit!!
Have you looked at the Gigabyte Radeon R9 280X OC??
Is it the width or the height of the card which is the problem??
The card is not fine because of its height! It conflicts with the PSU. The length and the width are ok. Please bear in mind I also have a Creative labs z sound card.
Γιάννη/Yanni, the Asus 7970 DC2 Top is 3 slot height and standard length.
If only the height of the card is an issue, consider to replace it with a 2 slot height one, either by trying to exchange or or downgrade to a 7950 with some extra cash left.
However if the length of the card is the issue also, seems you have only one option.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-317-AS&groupid=701&catid=1914&subcat=1830
Also configure your trust account to pm you in Greek if needed.
Γεια σου πατρίδα!!
Well, this is my plan. I am trying to find a used 680, 670, 7950 or even 770 to fit it in the case.
