you can not compare height for heightWhat height are you? I'm just under 6ft 3 and don't find it a problem to be honest.
some people have longer legs and shorter torsos others are the opposite etc
I've heard it can be a tall order to find the right shirt......
I get my work shirts from M&S i get 3 pack of white shirts.
aren't you like 5ft tall?
Where did you get that from?
I am over 6 foot and 95kg
My problems with finding shirts that fit my neck and are not too wide in the chest and im too fat for slim fit. I also find slim fit unconformable, even when i was not fat.
You would probably fit into corset well. Just saying. Look well pretty....little bit of make up and bingo.
My favourite at the moment are the slim fit range from TM Lewin. They do three different sleeve lengths although the extra long (38 inches my size) are being phased out I was told. I am 6'7" with a 17" neck, chest 46" & waist 36". They fit very well.
I have a few M&S 2" longer and there were good before I found the slim fit ones (not that I am slim).
I noticed a recommendation for Charles Tyrwhitt earlier. There longest sleeves are not as long as the TM Lewin ones (they only go up to 37").
