I've just put together a 4770k build, and I've decided not to try and squeeze a custom watercooling loop inside the case (Bitfenix Phenom).
I'm a little behind on which are the best Air coolers out there, or even AIO water coolers.
Can someone point me in the right direction? If the AIO's are the best, can someone point me to one with a low FPI rad/good for low noise?
The CPU cooler would also need to clear the ram (corsair Vengance pro) so I can't use the NH-D14 I believe..
Thanks
Thanks
