** OcUK EXCLUSIVE: GIGABYTE GTX 780 GHz EDITION BUILT FOR OVERCLOCKERS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
There is a lot of talk about GTX 780 GHz GPU, well OcUK has secured an exclusive on Gigabytes card. You will find companies like MSI won't bother with such cards as their Lightning Editions will already be using B1 stepping GPU's, also companies like Inno3D. But anyone who wants to be guaranteed a GHz core, Gigabyte now offering it.
How does GHz GTX 780 differ? The GPU is identical, it is just a new stepping with high frequencies out of the box, giving it better out of the box performance and potentially better OC headroom, though that is yet to be proven.
Gigabyte GeForce GTX 780 WindForce 3x "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £449.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
- OcUK has secured an exclusive, only OcUK will recieve stock in November!!
- GHz GTX 780 GPU - Best for Overclocking!
- Boost clock OC to 1071MHz
- Enhanced back-plate for asthetics
- 8-Phase Power Design
- WindForce 3X 450W Cooling System (2-Slot Design)
- Black PCB
Specification:-
- GPU: GeForce GTX 780 GHz
- Core Base Clock: 1019 MHz
- Core Boost Clock: 1071 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £449.99 inc VAT.
ORDER NOW
ALSO GIGABYTE HAVE MANAGED TO SHIP A SMALL AMOUNT OF REGULAR GTX 780 TO US TO GET HERE TOMORROW, FOR THOSE WHO WANT A BARGAIN, HERE IT IS:-
Gigabyte GeForce GTX 780 WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) @ £399.95 inc VAT
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- WINDFORCE 3X 450W Cooling system
- Black PCB
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£409.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Very tempted by the regular version as a change from my sli 670's. Great price on it.
Are you not tempted by say 770 SLI? I personally do not like dual card solution but i was even tempted by the thought of SLI 770 4GB cards. When you sell the six free games you should not be that far off £500.
Thinking of going for one 780 to start with then add another secondhand one later. My current cards oc'd wouldnt be that far off sli 770 speed. Tbf, sli has been exceptionally smooth for me with theese cards. May just wait and see what the 780ti is like.
Oc'd, the cards i have will surpass stock 680 speed. So no real point looking at the 770 series.
How does the non ghz gigabyte card compare to the evga acx sc?
Had a few evga cards and never had any problems with them.
The evga seem like they clock a little higher from reviews.
For £399 with 3 games its very tempting.
I don't regret getting my 780 mate, damn good performance! I nearly bought another this morning after seeing some crazy deals but I don't need that level of performance yet. They're that fast.
looks nice - I was tempted with a stock Gigabyte 780 OC earlier but not sure now
wonder why they've not overclocked the memory to the "GHz" touted speeds - are they still using Samsung ICs ?
dillema now - wondering if it means they are binning the cores, and if I now go for a standard one lower chance of getting a decent overclock :(
decisions
decisions
Buy both and send the duff clocker back.
^^ lol - I only just read it states that the Gigabyte "GHz" will be B1 steppings - interesting
is the product ID for the standard Gigabyte 780 OC correct ? I'd have thought now all new ones being sold were V2 editions with the dual 8 pin power inputs ? I'm hoping these are - and just no V2 in the product ID
Interesting, which Inno3D would that be? Are any other cards secretly using B1 steppings? Any reference coolers with B1?
Also, give us a cheeky wink if you have had a play with 780Ti.
Gibbo said:
I believe so, think V1 is long ago, V1 was blue PCB, V2 black PCB which they have being for a long time.
I have a V1 since 31st May 2013, and it's also got a black PCB, only way you will be able to tell is by the sticker, and of course the 8 pin, 6pin connector on the V2, as opposed to the 6pin, 6pin connector on my V1.
Will be nice if that GHz BIOS with the Core Base Clock: 1019 MHz works on normal card..
