i know it is only 10 pounds it does not bother me at all.. i am just curious why
It dosent bother me at all guys seriously... not bothering me at all.....
"Or it could have been assigned a system build, then the customer changed the build as he wanted a different graphics card, which changes the assigned graphics card which was off the website, onto the website."
so if i am thinking correctly this maybe means the card could go second hang in another computer for a customer?
I've never seen anyone so paranoid about getting a 2nd hand graphics card when they're buying new.
would you guys say the msi gtx 780 lightning is one of the best 780 cards out there, i have not really seen a lot of reviews
Seasonic X-Series 650w '80 Plus Gold' Modular Power Supply
:snip:
would you change anything in the rig to make it more bulletproof and powerful so that my card can get some overclock going on.
guys my budget was £1500 and after buying the msi 780 card for £480 it is now..£1020
MSI GeForce GTX 780 Lightning 3072MB GDDR5 PCI-Express Graphics Card
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW)
Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM
Avexir Venom Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz
BitFenix Shinobi USB3.0 Gaming Windowed Case - Black
Prolimatech Black Megahalems CPU Cooler Prolimatech
Noiseblocker BlackSilent Pro Fan PLPS - 120mm PWM (x2)
this is for my new pc what you guys think, would you change anything in the rig to make it more bulletproof and powerful so that my card can get some overclock going on. bear in mind i aint going for ultra benchmarking since im brandnew to overclocking a graphics card but i do not think its that hard after watching video's
So, fair enough you dont want to oc your cpu, (just go for the standard 4770 then) but why did you buy a lightning??? Are you not gonna overclock that?? Them cards practically beg you too!! Mine loves the high volts flowing through its veins
For the basket plugin go here http://forums.overclockers.co.uk/showthread.php?t=18371076
