** EVGA BRINGING THE SCARE FEST: EPIC GTX 7xx SERIES DEALS TO CELEBRATE HALLOWEEN!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some *WEEKEND ONLY* deals from EVGA, stocks are quite limited, so don't hang around:-
EVGA GeForce GTX 780 ACX FTW 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-3784-KR) @ £429.95 inc VAT
The EVGA GeForce GTX 780 marks an evolution in gaming performance ? an insanely fast, smooth, and whisper-quiet experience, every time.
EVGA is also introducing a brand new cooling design; the redefining EVGA ACX Cooler. With a 40% increase in heatsink volume, the EVGA ACX is more efficient at dissipating heat, allowing for 15% lower GPU temperatures. A reinforcement baseplate maintains a straight PCB, and helps lower mosfet temperatures by 7% and memory by 15%.
Even the fan blades are of the highest quality; with a 700% increase in strength, and 25% lower weight when compared to competitors. This makes the fans 20% more efficient by requiring lower power levels. EVGA is also using double ball bearing fans which offer a 12 year lifespan, 4X longer when compared to competitors!
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 980 MHz
- Core Boost Clock: 1033 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£449.99] Inc. VAT
Only £429.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 780 Classified "Dual BIOS" 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-3788-KR) @ £473.99 inc VAT
The EVGA GeForce GTX 780 marks an evolution in gaming performance, an insanely fast, smooth, and whisper-quiet experience, every time.
Features:-
Specification:-
- Dual BIOS
- Core Base Clock: 993 MHz
- Core Boost Clock: 1046 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£491.99] Inc. VAT
Only £473.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 780 HydroCopper 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2789-KR) @ £499.99 inc VAT
Looking to maximize your EVGA GeForce GTX 780 experience? The EVGA GeForce GTX 780 with Hydro Copper is the perfect match for any water cooled rig. The Hydro Copper waterblock from EVGA features a swappable inlet/outlet for the maximum in compatibility, and is a full cover, end to end block. A 0.25 x 0.35mm pin matrix provides optimal thermal transfer and ensures the lowest temperatures possible. Get cool performance today with the EVGA GeForce GTX 780 with Hydro Copper.
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£599.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 770 SC ACX Dual Bios 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2776-KR) @ £259.99 inc VAT
Fast just got faster with the next-generation EVGA GeForce GTX 770, a high-performance graphics card designed from the ground up to deliver high-speed, super-smooth gaming.
EVGA is also introducing a brand new cooling design; the EVGA ACX cooler. This revolutionary double ball bearing fans with an average lifespan of 12 years. This is 4x longer lifespan vs competitors sleeve bearing fans! Not to mention this fan is silent, in factr it is 15% quieter on average!
The EVGA GeForce GTX 770 is stacked with unique gaming technologies like NVIDIA GPU Boost 2.0 that make it fast. Really fast. So nothing will hold you back from taking on - and dominating - your most challenging games.
Specification:-
- Dual BIOS Version
- Core Clock: 1111MHz (GK104)
- Core Boost Clock: 1163MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2222MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 770 Superclock ACX 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2774-KR) @ £249.95 inc VAT
Specification:-
- Shader Clock: 2220MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£269.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 760 SC 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2762-KR) @ £189.95 inc VAT
The EVGA GeForce GTX 760 is the new weapon of choice for gamers ? a powerful graphics card that gives you the fast, smooth, quiet gaming you're looking for in all your favorite titles.
Specification:-
- Core Clock: 1072MHz (GK104)
- Core Boost Clock: 1137MHz
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 2116MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£194.99] Inc. VAT
Only £189.95 inc VAT.
ORDER NOW
These prices are below the NVIDIA new *Price Drop* price and as such they shall go back up on Monday, stocks are limited, so if they sell out first, the prices goes up then.
How is £10-£20 off scary? Isn't that the sort of reduction you normally do on a TWO, today only and Weekend only deals any way?
Its only the watercooled one that's got any sort of real reduction but then it was due it any way as you can buy a 780+water block for cheaper now.
Is the classified worth the £50 over the ftw? Other than the dual BIOS and slight higher clocks does it have any thing else?
I've yet to finish building my PC so not checked the 290x to see if there is any issues like some of the people have reported in the 290x owners thread, if I do want to RMA under the dsr/14 day satisfaction is it 14 working days or does it include weekends as well(I know the normal DSR is 7 working days, I'm not sure about your extended period)? And is day it was delivered or day after(I got it in hand last Friday).
Then if I do decide to return need to decide which 780 to go for and the 780ti will be too much, from what I've read evga cover stock cooler removel in their warranty.
EVGA allow you to remove cooler.
Our prices are good, sales are extremely strong, its a marketing promotion.
Any chance for 780 SC 2783 or 2784 models to be in stock by 15th this month?
Not interested in FTW, since I can't fit EK blocks on one.
Cheers
GTX770 SC ACX was £80 cheaper than when I brought it last Thursday! So angry that it keeps dropping to much
And now you get two more free games!
Wish I had waited....
Do we get the 10 year warranty here in the U.K from EVGA?
Hi,
we changed our warranty system and actually cards do come with the KR warranty. This do mean the card do have out of the box three years of warranty and if you want to you can purchase up to 5 or 10 years optional. You can find more information about this at eu.evga.com/warranty
