Battlefield 4 Thread ~ Server details in opening post ~
If anyone fancy's a game at the weekend Ill be on most of the time (friends have gone away! wrong weekend to do it!).
Origin name is same as forum name: xGBHxPegasus
Can you add people's battlelog names to OP in a list?
:)... think we need a list of names on OP or something. I did try make a thread awhile back but got told just post it in this forum, Just think it would make it easier for people to add other members saves searching through all the posts.
Ok, I've started a simple list and you should be able to add yourself to it. I will put a link in the OP.
https://docs.google.com/spreadsheet/ccc?key=0AkS-9WXjtBqcdGpadFhBNHYxWWRudzZMSlJ4M0NPYkE&usp=sharing
10 mins of gaming, crash, 5 mins of gaming, crash, 3 mins of gaming, crash, join a game, crash, try to join a game, crash, launch IE, crash....
*sad panda*
Resolution scale is definatly a GPU stresser. Ran much much hotter when i upped it to 140% with all settings on max. Averaging about 60-70fps on that.
It did, they have changed the hardcore preset for BF4. No hit markers, no mini map ......
I don't mind the no mini map bit but it's hard getting used to whether i'm actually hitting someone or not without the marker, lol
Up close it's no biggie, it's the long range shots that are a pig.
Question on double XP you get through Battlepacks. Are they cumulative (i.e. get 2 x 1 hour for 2 hours total" or is it better not to open a second battle pack until the first hour of extra XP is used up?
AFAIK you have to activate them anyway?
Arent they the boosts thing mentioned in the menus?
Was holding onto my 100% increases until the double XP days :p
*sad panda*
I'm finding if I run it at 64 bit from Origin then the memory usage goes trough the roof in Task Manager. Then the game crashed. When I run it from 32 bit, its fine.
I want to run it at 64 bit, so I will have to work out what the problem is. Maybe I should set video to Low.
Anyone else offer any ideas?
Memory leak perhaps
but so far Im pleased with Battlefield 4, as I said last night I like the 'chunkier' feel to the game, much better than B3
Runs nice and smooth, smoother than BF3 I would say. That said not too impressed so far, I don't know what it is but I think I was expected more.
Graphically I can not really tell the difference and the gameplay feels pretty much the same.
I am very much a casual gamer these days but yeah that's my thoughts.
I'm probably wrong.
but has anyone thought the BF4 crashing it related to your Overclocks being a little to much?
I remember BF3 pushed some machines over the edge As it used Everything it could?
Just a thought. :)
not tried it going to tonight
