Battlefield 4 Thread ~ Server details in opening post ~
anyone have any decent graphics settings for a 670gtx, rest of specs in sig.
It defaults to ultras but i think thats a bit ambitious for multiplayer
Getting the crashes here. Quite disappointed the game doesn't seem to have improved fps wise since the final beta build. A mid to high overclocked 7950 just isn't seemingly enough for smooth gameplay at 1080p high settings all round and 2*msaa.
Seriously tempted by a 780 now.
depends what fps you want at high it should fly through it @ 1080 a high clocked 7950/7970 not far off a 780 probably 5 fps mins.
if you want 60 mins a 780 gtx wont do that you need two cards or 7990.
fak!
I preordered through Origin, got my email this morning and my game will not appear in the Origin app.
when I try and redeem my code, it still doesn't appear...
Origins support are less than helpful.
anyone getting the crashing to a red display after a round finished, happened 3 times.
I did have the task manager showing memory and disk at nearly 100%, but I took the overclock off my card and seems to have done the trick for now.
It doesn't fly through it at all with 2*msaa. Big difference between bf3 at ultra 2*msaa and bf4 at high with 2*msaa.
70~ people on my friends list and only 1 person playing :( I guess it's not just me that's tired with the servers going down, or crashing. Beta worked fine, what the hell did they do! D:
so is this worth a purchase? love bf but worried my 670 isnt up to bf4 :(
I've got I7 920 D0 oc'd to 4gig with MSI670 not OC'd and on medium I'm getting 120 fps at 1920x1080. Can probably put it up a notch but I want it to be stable fps...
Glad I didn't upgrade my mobo & CPU though.
On Win 7 ^^
looking to get my pb guild this not working on bf4 what i did for bf3 anyone know how to get it
Method 3:
•Navigate to your pb folder
C:\Users\\AppData\Local\PunkBuster\BF3\pb
•Create or edit a file called pbcl.cfg in the pb folder
•Add the following line to pbcl.cfg: pb_logtofile 1
•Save the file and join a PB enabled server
•In the pb folder you should see a pbcl.log file within it should be a line starting with:
PB Server assigned guid =
Obiliteration mode really seems to be like an envoled capture the flag. Seems like a lot of fun, good to spectate too.
To be fair to dg, a 7950 does fly through it at 1080. Mine with a i5 at 4.2 runs smooth as butterwith everything ultra and 4xmsaa with no motion blur.
anyone playing this on a q6600 running at 3Ghz+ and a ati6950 or something near this spec?
interested in how it plays (I use 1650x1080)
cheers
