- 4 Jan 2013
- kent
hi guys & girls,
i have a sapphire hd 7970 oc edition, and i've just had to update my drivers to 13.9 as i have the new battlefield 4 and it didn't recommend i play it on the drivers i had previously.
but since drivers 13.9 on i have masses of coil whine. i used to get it a bit before but now it's really bad.
i didn't think drivers would cause this kind of problem?
any recommendations?
also, if no solution is found, will it be ok if i just leave it as it is, or in the long run will this damage my card?
whilst on the subject of coil whine. my psu which is a seasonic m12 2 (i think)
also has coil whine after playing a game or being under load for a while. it's only recently started doing this and if i tap the back of it, it'll then stop for a while. should i be concerned?
thanks in advance,
scott
thanks in advance,
scott
