Battlefield 4 Thread ~ Server details in opening post ~
Game keeps crashing on Campaign :/ Trying to load my mission save in, on #6, it gets to "faintest trace on their signal" then just crashes with the "BF4 encountered a problem". Highly annoying.
Only thing that can save this game is Operation Metro in the DLC pack xD
I am really hoping DICE can make metro what it should have been. It has soooooooo much potential, they need to use the street above it + have a big levolution event, something like what happened in die hard 3 :cool:
Tbf ive only had a chance to play a few maps today. Regarding metro, i agree that the whole map including the outdoor rush section would be ok. As it stands at present its just a clustered explosive spam nightmare.
I've had no problems apart from the 'lag'. I've managed to avoid it by going on 32 player server only. Other than that *touch wood* no bad experiences.
Locker is actually a pretty good map with 32 players, I like how there are quite a few flank areas.
Just needs some medics to realise what their job is. If you're on the receiving end of said flank areas, you need a good medic running around getting you up again.
I'm yet to find anybody.
I'm enjoying most of the maps, dawnbreaker if theres not a crapload of snipers on the roofs 64v64 was quite epic. One odd thing I think with a lot of the map designs, there always seems to be one spot that's way out there. D I think it is on flood zone by the petrol station, one team takes it and it tends to stay that way for the entire map or if it is taken its with no opposition as people cba to run all the way over there :p
Our Defuse Hardcore server has been up for ages, but the large server trips over like a 2yr old every 1-2 hours.... so bloody annoying.
R3 - Laggy but less crashes
R4 - Crashy but less laggy
:D
Yeah I need to revive more in this game, haven't done it much as when I do, I always get killed and then the enemy will push through. Plus I think people are just a bit more cautious about who they revive and when due to limited amount + takes longer.
+1
I spend most of my time going only for a few flags simply due to that reason, I think seige of shangai is probably the best designed map so far overall, perfect for flag distance + plenty of ways, only annoying thing is roof campers although it isn't as much of a problem with 32 players.
Well this is annoying I am having a great game of obliteration and I get a CTD:( Just curious does your progress get saved or I have lost the near 10k points that I had.
Anyone using a 7970? Averaging 70c on a large conquest 64 player map. Anyone know if this is a reasonable temp? This is with GPU fan speed at 65-70%.
Thanks in advance.
wow it's unplayable tonight been rubber banding, lagging all over the show! Even the sound cut outs.
Yesterday was PERFECTION!
I think the main reason for this is that the carbines are very strong. I play almost exclusively as engineer because you can just play more effectively. I think if the respawn time was longer and they further increased the time to revive and reward for reviving, there would be allot more incentive to play medic.
On BF3 it used to keep your points if you didn't reconnect to the same server. Not sure about BF4 though.
Also don't forget there's a possibility some haven't unlocked defibs yet or haven't got it selected as you can choose med pack and M320 and no defibs now.
I know it's still early days. I guess I'm just used to playing infantry only with a load of hardcore medics :p
