Think I'm finally ready to pull the trigger and grab the Asus HD 7970 Matrix Platinum 3072MB while it's on sale, and just wanted to do a finally check before I do.
The £240 is pretty much my limit for what I would be willing/able to spend, so is there any other card that would be a better choice, performance out of the box or potential wise, that is same price or under?
My specs are/will be:
Intel Core i5 2500K
Asus P8P67 Intel P67 Mainboard
Corsair Vengeance Low Profile 8GB RAM
Samsung SpinPoint F3 1TB SATA-II
Samsung 120GB SSD 840 EVO
XFX Pro 650W Core Edition Power Supply
Windows 7 64bit
May be switching out the motherboard for the Gigabyte Z77X-D3H Intel Z77, as I hear there could be an issue with my P8P67 as it is the B2 revision and cannot update the bios.
No compatibility issues? Power supply sufficient?
Case is big so size shouldn't be any issue.
Thanks.
Intel Core i5 2500K
Windows 7 64bit
Thanks.
