Half price halfords advanced socket sets
I think I've heard good things about Halfords Advanced stuff. I can't find confirmation on the site, but I'm sure I've been told that they have a lifetime guarantee - if a socket splits, you just take it to a Halfords branch and they'll replace it, no quibble.
Yes this is the case :)
You should have the recipt too, but ive heard of people getting replqcements without them. Very good kit the Halfords stuff.
I have had my set a good few years and it is fantastic. If anything breaks you just take it to halfords and they will replace on the spot. Good quality tools as well.
I bought my set second hand when I started my apprenticeship. So I've had it over 5 years and it's a couple of years older than that. Only even broken torx bits which is normal. I broke the 3/8 ratchet using a 4ft bar on it. Other than that the rest is all still there and still solid. I really can't fault them at all for what they cost.
