ASUS To Have Exclusive Rights Over G-Sync
1) Asus does make 120hz+ monitors
2) Asus does make IPS-panel based monitors
I was worried we'd be 12 months further away from 120hz IPS monitor. Fingers crossed, we're not. Expect it to cost about £600 though (for a 24" / 27").
There's no indication we are any closer... 120hz is not a requirement for gsync
I am not sure why people keep saying 120Hz is needed or apparently thinking 120Hz is needed. It will be available on any panel that has signed up with Nvidia and from 60hz 1080P all the way through to 4K monitors.
I think you should specify, it will be available on MOST panels in the future for AMD and Intel customers.
It will be available to Nvidia customers only on screens by companies that pay Nvidia to not disable the feature for their screen by joining the g-sync branding and increasing the cost to Nvidia users ;)
Just out of curiosity, you do realise that 3d vision, is nothing, it's 3d, that is handled mostly by the screen and the game maker, and needs no involvement from Nvidia or AMD.
AMD are giving up on 3d as they have no intention of paying off every dev to create a 3d AMD game.
Every 3d vision screen is simply company X paying a certain amount of cash to Nvidia to be able to add 3d vision branding at which point Nvidia DON'T arbitrarily stop 3d from working on that screen? That is ALL it is.
Crysis will work fine without the driver, from the game, with a 120hz 3d screen, that's it, that is as complex as it needs to be. Nvidia decide to try and make money from it, lock out those who don't conform and pay game dev's to lock themselves in to 3d vision.
G-sync is no different. Please ask yourself what the screen is doing for g-sync that is so different to now.
Currently right now your monitor receives a new image and stuffs if in the screen buffer while also having a little timing program that gets set to 60/75/120hz or whatever else and simply updates every X ms. G-sync is this screen buffer getting updated, but instead of having a set refresh rate defined by timing, it just updates when that screen buffer gets updated...... the graphics card operates in normal mode without v-sync enabled, nothing else is happening. They want to charge you £100 for this OR they will lock your screen out from working in the driver.
Depending on the prices silicon many screens currently might be capable of this with a simple firmware update, it's utterly, completely trivial to add that mode into future screens which will have new controllers anyway. Nvidia can not own a patent on that. if g-sync is worthwhile(the difference from the absolutely perfect conditions demo vs the game was massive, and the game is all we'd care about) then EVERY screen will be able to do this and the only reason you won't be able to use them is Nvidia blocks it in the driver, as they have done for a decade on hundreds of motherboards for SLI, hundreds of screens for 3d vision and the physx gpu acceleration lock out if an AMD card is present in the system.
This is what Nvidia do, take something "standard", lock out everyone that doesn't pay them, calls it a feature and charges you for it.
People have hacked drivers to make 3d vision work on non 3d vision screens, to make sli work on other mobos, to make a nvidia card for physx work when the main gpu is AMD...... but don't worry. Why do I think this is the same...... why don't you think it's the same?
What g-sync boils down to is literally no difference gpu side, and an absolutely trivial change screen side....... rather than Nvidia go the good route, "hey we pushed them to do this, we improved gaming for everyone, isn't that good". They've once again gone the "this is a minor change, AMD/Intel users wouldn't lock people out so they'll have it free as every monitor maker will do it, Nvidia users, we're going to limit which screens you can use and charge you through the teeth for it..... Nvidia users lose..... no one else does.
Patented, good luck to anyone wanting to copy it without a massive lawsuit
lol, if you think Nvidia can patent anyone else from an arbitrary, trivial change in monitor controls.... well that would also mean that those people who currently make screen controller chips(IE not Nvidia) would prevent Nvidia being able to make their "g-sync" screen controller chip as 99% of the functionality is the same as existing screen controllers.... yet Nvidia can make this chip, it's almost like you can't arbitrarily patent simple features.
They can patent their controller because it will be their design, nothing more or less, they will for a fact not be able to prevent other people making their own chip with the same feature.
This is Nvidia marketing telling you that only their chip can enable this "complex"(yet actually insanely simple) feature and thus fully not screwing you over charging you £100 for a $0.03 change to existing controllers.
If it were so simple, why has no one else done this?
Having looked up (patents are public record, they have to be so that people can avoid breaching them) nvidia have several patents related to syncing, they are not for a chip design
Im not sure you could even patent a design for an FPGA anyway, seeing as they are reprogrammable, it would have to be the concept that the chip provides and not the chip itself which is basically an off the shelf programmable module
Sales costs for items usually does bear the cost of research and development, pretty sure that this cost more than 3 cents per item in R&D
FPGAs cost considerably more than 3c as well, ASIC version should be cheaper as it replaces the existing ASIC, but even then retooling for an asic costs more than 3c
so basically everything youve said just looks like bitterness
for examples of how basic patents can be, just look at the constant spats in the mobile phone industry
