GTX 780 power connectors
The 670 has two 6 pin connectors. It comes with a 6 to 8 pin connector anyway.
Sweet!
thanks guys
Before using an adaptor just check your 6 pin connector leads as most modern psu's have 6+2 connectors, sometimes the two pin connector has just been folded back, you would find the two pin connector attached to the same lead as the six pin connector, if this is the case just line up the two pin along side the six pin and hey presto, 8 pin connector. If not then adaptor will be fine.
Cheers fella
thanks for the info!
I had thought that this might be the case. Ill check when i get home from work!
Chris
