- 11 Dec 2005
- Cheshire
The highlights of this week's deals are as following:
This week we have a crazy deal on the Samsung S22C300BS 22” Widescreen LED Monitor, available for less than £100 at only £99.95 inc VAT! Featuring a full 1920x1080 resolution, grab this monitor before stocks run out!
Build your dream LAN system with the BitFenix Prodigy “Gamma” Mini ITX case. Finished in the classic orange & blue colour combination for a truly unique looking system! Customised in house and only £61.55 inc VAT.
Boost your systems graphical horsepower with the brand new AMD Radeon R9 270X Boost OC 2GB graphics card. Delivering stunning DX11 cinematic graphics and true next gen performance for only £143.99 inc VAT.
Want more? Our whole selection of deals HERE.
Samsung S22C300BS 22" Widescreen LED Monitor - Rose Black @ £99.95 inc VAT
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SC300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SC300 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
- 21.5" (16:9)
- LED Technology
- Resolution: 1920x1080 (True HD)
- Contrast Ratio: Dynamic: Mega DCR (Static: 1000:1)
- Brightness: 250cd/m2
- Response Time: 5ms
- Colour Support: 16.7M
- Input Connection: 1x Analogue & 1x DVI
- Stand type: Simple, tilt function only
- Wall Mount: No
- Set Dimension with Stand (WxHxD): 512 X 385 X 197 mm
- Set Dimension without Stand (WxHxD): 512 X 311 X 53 mm
- Set Weight with Stand: 3.0 kg
- Cables: D-Sub Cable included
- Apple & PC compatible
- 3yr Warranty
Only £99.95 inc VAT.
ORDER NOW
BitFenix Prodigy 'Gamma' Mini-ITX Cube Case - Orange/Blue @ £61.55 inc VAT
We have made some amazing improvements to the Prodigy cases. Orange & Blue. These new options offer great new stylish designs.
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- Cooling Top: 120mm x 2 (optional)
- PCI Slots: x 2
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Only £61.55 inc VAT.
ORDER NOW
Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card @ £143.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1020MHz
- Core Boost Speed: 1070MHz
- Shader Architecture: GCN
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 180W TDP
- 2yr Warranty
Only £143.99 inc VAT.
ORDER NOW
- 21.5" (16:9)
- LED Technology
- Wall Mount: No
- 3yr Warranty
ORDER NOW
- PCI Slots: x 2
ORDER NOW
Specification:-
- Power: 180W TDP
- 2yr Warranty
ORDER NOW
