Caporegime
- 7 Apr 2008
- Lorville - Hurston
Counter Strike?
Computer Science?
Tear gas?
Customer service
Counter Strike?
Computer Science?
Tear gas?
For anyone looking for lock screen Notifications, I reckon "NILS Lock Screen Notifications" is better even than Dashclock, it gives previews of Texts, BBMs and E-mails, it's about as close to IOS as you're going to get with it.
They don't offer refunds on SIM free phones.
can this be used with stock launcher?
Well I ordered online so DSR appliesWill try to return it in a store this week and see what they say, but I can't see how they could refuse?
But I do like it, I'd keep it if I didn't already have the HTC.
You guys really rate the camera? My main issue is the focus speed, and the fact that it doesn't always focus correctly. You might be right though, and corrected soon through software in which case the kinks could be ironed out.
Iv'e read that this is a design feature ... the idea is that if dropped it will be the shell that hits a flat surface and not the glass which may give some added protection ... apparently it was the other way round on N4 (screen protruded above shell) so it was highly likely that if dropped then it would hit the screen with likelihood of it cracking.can aonyone confirm if their phone screen is slightly sunk compared to the shell around it. we're talking less then 1mm. i'm not sure if perhaps mine is sunk more then it should be hence the sides feeling sharp when swiping in, esp from the right hand side.
Also if you go to 'People' and change 'Contacts to display' to 'your gmail account' and then go to the dialler and tap 'All Contacts' it does not carry over and Contacts from all accounts are in there. Very annoying.
Camera focusing maybe fixed with a software update, don't be too quick to judge it![]()
Lightflow app updated on play.. mine appears to work so far![]()
Anyone else getting a bug where the camera fails to start when opening the camera app? I.e. Camera app loads but screen blank apart from camera icons? Happened a couple times to me today.
