Did this really need its own thread? When the cards not @99% load the card doesn't get as hot...
Captain Obvious
Much better than captain rude.
Vsync helps keep cadds quiet, but if you lomit the fps with say radeon pro it has the same effect but no input lag.
So kill performance to keep the card quiet?
How are you killing performance exactly?
A million fps doesn't make the game any better, ill agree 120 is nice but for most 60 is plenty, im not sure why the negativity, im sure many didn't realise vsync make the card quiet and they can play all their games maxed, what more do you want?
Just trying to let people know, not everyone cares about overclocking for a few more fps that doesn't achieve anything, a lot of sites report the noise and while it is a bit loud thats because its pumping out a load of extra fps that isn't needed by most running 1080p with current games.![]()
A guy just posts a harmless thread mentioning something he thought could be useful and all he gets is people coming in and letting him know that because they all already know what he's saying its pointless, great what an amazing bunch.
And to be fair vsync and or frame limiting does make the cards quieter just by the fact they dont need to run at full tilt, nobody is making you use it he's just mentioning it.
V-Sync incurs input lag and that isn't something I enjoy. I am bad enough as it is without help from input lag.
http://forums.overclockers.co.uk/showthread.php?t=18551579
http://forums.overclockers.co.uk/showthread.php?t=18551717
Then post in there? Wasn't a need for a whole thread, i might make one telling people to use a waterblock and a custom loop because the noise subjectively is non existent (well in my case, as i have no fans!)
V sync makes most games unplayable, though D;
Just cap your frames at 60fps or what usually works better cap them a few fps under your refresh rate, no screen tear and none of the negatives from vsync.
Also, vsync doesn't keep the cards quiet it limits the potential load of the card by capping the framerate.
If there's any input lag i can't say i've noticed but id rather have a quiet card with no more screen tearing.![]()
