new pc
I would get a better case, psu and you really want quad channel ram for 2011 socket.
why a better case? case is a case...
what psu would you suggest for a similar price? (and why)
quad channel, ye you could but your going up in price for not much return..
If your going to spend the best part of £1000 why would you go for a very basic/budget case that has very poor airflow out of the box (Only 1 fan pre-installed) You would then need to spend money on extra fans which is defeating the object. I usually say around 10% of the overall budget for a case.
OCZ psu's are not the best, and they are apparantly in financial trouble. I would personally go for an Antec, Seasonic or Corsair.
Socket 2011 supports quad channel ram which equals more bandwidth, so why not use it ?
Here's my choice,
YOUR BASKET
1 x Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £259.99
1 x Gigabyte Radeon R9 280X WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card £245.99
1 x Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard £169.99
1 x Patriot Viper "Black Mamba" Generation 3 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PV316G160C9QK) £119.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
1 x Antec High Current Gamer 620W '80 Plus Bronze' Power Supply £79.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £44.99
Total : £1,090.48 (includes shipping : £10.50).
Better PSU (Seasonic inside)
Retail CPU (3 years warranty instead of 12 months)
Quad Channel RAM (Makes better use of the extra bandwidth on X79)
Better Base (both in terms of looks and airflow)
Better SDD ( The Samsung 840 EVO pretty is the best and fastest drive out there currently on the market)
Better cooler (WATER DEAR BOY) ;)
AMD R9 280X !!!! in high res gaming the extra VRAM will be very useful to you, and its Gigabyte which has a UK RAM base if anything bad should happen.
Here's my choice,
YOUR BASKET
Thats so much better OP.
Hey thanks for the help guys, i decided to go with
YOUR BASKET
1 x Gainward GeForce GTX 770 2048MB GDDR5 PCI-Express Graphics Card £239.99
1 x Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £239.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
Total : £1,078.37 (includes shipping : £11.25).
but i seem to be having a few problems with powering it up. It turns on for about 3 seconds then immediately shuts off, then turns on again for 3 seconds then turns off in a continuous loop also with no beeps, all the fans seem to be working aswell but when i watch the CPU cooler, the indicator light has a dim flash then shuts off.. but i made sure its fitted correctly so i'm not sure whats going on, maybe a problem with the mobo?
I've made sure the 2x4 12V Power connector and the 2x12 Main
Power connection are plugged in aswell.
Correct me if I am wrong, but wont he need a SB-E chip to do that.
Yep or send it back to where it was purchased from to see if they will carry it out or see if Gigabyte will do it for you (they are in Milton Keynes).
Or if he's close to me I can do it.
I would agree with this as that chip was released after the chipset so will require a flash the only problem I can see is that the OP will require a Sandybridge CPU in order to flash it if he can't get into the BIOS.
This is right, been in the exact same position as OP and had to stick a SB cpu into my mobo first before sticking my IB cpu in.
