26 or 27 AWG multi core wire?
16 Oct 2008
Does anyone know where i can buy this in Black and Red, I have searched everywhere i can find and have ended up buying from someone in China, it's for the wire that goes from motherboard header pins to LED's for power/HDD LED's etc, the problem i am having with current wires at 24 gauge is the plastic on the outside will not fit into the hole, so i need smaller but it seems rare as rocking horse poop.
I have reported this post to mods on my own as I'm not 100% sure if I'm breaking any rules.
All1
Just to add a pic so people know what i'm on about it's where the Blue & White wire goes into the plug
All1
The only rule you're breaking is obfuscating an expletive.
I used the ebay seller spiratronics recently for a large order of wire and they were excellent. They might carry it.
USB 2 cable contains some thin wall 24AWG cable that'll probably fit. The other pair is not red black but is 28awg and would be fine for this purpose.
Look for UL1007 cable if buying from abroad as that's thin wall.
The ptfe cable listed on Farnell will be not very flexible.
Thanks for that info Tealc that info has come in very handy as the problem i'm having is the wall is normally fairly thick so this info is very handy.
All1
