- 12 Jul 2013
- Dublin
Gentlemen,
I'm torn between 'upgrading' my current system to either 780ti's or R290X's. I currently have 3 Titans all underwater driving 3 monitors giving 7680x1600 which if my quick calculations are correct is approx 35% more than a single 4K screen.
Since I'll be putting them underwater, the cooler noise of the 290x's wont be an issue. All the graphics cards are on a 480 + 280 rad. The CPU and mobo is on a separate loop so there is plenty of cooling capacity for the GPU's.
The main issue I have is that the Titans I have dont overclock as well as I'd like due to whatever reason. My brother will happily take two of the Titans off me so that's giving me the itch to upgrade *if* it gets me worthwhile performance gains.
I'm leaning more towards the 290x's as the few SLI/CF reviews Ive seen so far would suggest that the 290x's in CF pull ahead of the 780ti's at 4K resolutions.
VFM is not really a priority. I'm looking for whatever will give me better performance at my current resolution.
Yes....I know I'm insane but I've gone past caring about that long ago!
I should probably wait for non-ref 290x's but if the improvements there are only on the cooler then there probably isnt any point in waiting.
Cheers.
Cheers.
