Best in-ear earphones
28 Nov 2008
UK
Hi
On schedule my Shure earphones are atarting to split 4 years later. I was wondering what the latest decent sets are.
I am looking to spend up to £175.
I've noticed Bowers and Wilkins' latest C5s attract good reviews and are on sale for £99 instead of £150 at an online retailer.
Are there any others I should consider?
I don't know about 425 but I've had my shure 535 for over two years now and the are excellent.
well theres no such thing as "best" but seeing as you dont say what you had or what you are looking for from the new ones its hard to give a tailored suggestion.
Have Etymotic Research HF5 myself. Think you can get them for about £110 now, Really nice neutral sound, and no over the top base.
Excellent customer service as well (US Based) pair broke after 12 months and they instantly replaced them no questions asked.
have you seen this amazing collection of reviews spread across a wide variety of price ranges, its how I decided on mine, worth thinking about what you want sound wise and reading through them, then seeing if someone stocks it in the UK:
http://www.head-fi.org/t/478568/mul...red-custom-art-music-one-added-10-28-13-p-796
personally I have always wanted a pair of Fischer Audio DBA-02's but never managed to find an importer that deals with them.
those E10 things which are less than <£50 apparently are the best for the money.
after that you end up paying a lot more for little return, unless you buy headphones.
Not really IEM's do get better the more you pay, but after about £300 things start to get very expensive for small differences. For a cheap pair I highly recommend the Shure SE215.
I went with SE315s after looking a few months back - my e3c's finally died, and I was prepared to break away from Shure if needs be.
In the end, however, for the budget, I think that the SE315s were an excellent choice. Have to say that IEMs (well, Shure ones anyway) have come on a lot over the years - not just in sound quality, but also fit!!
Yes Shure are a great brand.
I just bought some sound magic E10M, wanted the mic, it'll do since it's for trains and stuff from my phone and serious audio sessions.
E10 arrived today, been using it practically all day and my impressions are that it is good value for £40 (mic version). Sounds quality is better than some but not as good as my ety, or full size headphones. The seal is okay, not the best, the mic is poor, made a phone call and it was so bad I unplugged it and used my phone normally, the other side just couldn't hear me. For some reason I can hear the background noise that the mic is picking up through the earphones. The remote works but it is difficult to feel what button you are pressing by touch, they should have added a little pointy bit on the middle button so you know you are pressing that, because they are all flat, you can't feel it at all. Half the time when I want to turn the volume up or down I am pressing the flat area where there is no button, or when I want to skip a song I end up pressing the volume button.
So my thoughts, it is price just about right, and I wouldn't say it is better than £100 headphones or my £70 ety because it is not. It is good for sound quality, but has a few design flaws, and a terrible mic.
Build quality is ok I guess, will see how durable it is, and as bad as apple earphones are, they last for ages.
