Pokemon X and Y - 3DS - Oct 2013
Favour lads, I'm now on post game stuff and looking for some good Pokemon in the Friend Safari. Can you all add me and I will do the same and add all the codes in this thread?
Friend Code - 4742-5377-3796
Added you (and everybody on the first page), add me back please :p
2466-2124-8893
Pretty sure someone on here has a ditto fs as I've used and abused it.best I've managed is 3 perfect iv on a single ditto.
if your breeding make sure you get hatching o power. Can hatch most non bagon eggs in less than 3 mins with lvl3.
Hm it's convoluted but once you have all 15 other o power you need to max out your luminous city style by buying 100 premier balls one at a time and then the guy appears in a cafe and gives.
Ah right, cheers!
I now have a X/31/31/X/31/0 Ferroseed with Leech Seed and Spikes :D. Now to breed it and try for the 31/31/31/X/31/0 :p.
Ah right, cheers!
Good going, I've just decided against ferrothorn on my team, but it was a hard decision :p
Finally bred my 31/x/31/31/31/31 modest litwick. Made a few words whilst breeding this one, so took far longer than it should have.
Okay got everybody added I think, hidden abilities from the friend safari.. how do they work? If your friend is online at the same time as you are you have a chance that whatever you catch from their safari will have it's hidden ability is that right?
I was put off at first due to needing 0 Speed and eggs moves but it was pretty much painless in all honesty. Got a 0 speed Ferrothorn in about 30 catches from the friend safari and passed down the egg moves easily enough from the Cacturne. I can also trade you a spare should I bother to get one (I have the perfect female but going to breed for a perfect male and then finally get a third 'perfect' Ferrothorn which I'll use :p).
As long as the 3rd Pokemon is unlocked (You're both connected to the internet in game at the same time at least once) you have a chance to get the hidden ability. I'll check your Safari now if you want :)?
Edit: You have Combee, Volbeat and Venomoth.
Care to share where you got it from? ;)
The Neoseeker Pokemon X/Y forums, they have a subforum dedicated to trading Friend Codes which is pretty active.
Spent a good few hours catching more Dittos last night, got about 15 with 3 IVs and one with 4 IVs now. :)
Lads can anybody who hasn't added me please do so? 4742-5377-3796. Really appreciate it, don't have any fire or water safaris at the moment and I'm looking for a Protean Froakie so I'm a bit stuck -_-
I have one of these, I'll try and remember to check back after I'm home as I'm going out in a bit.
