- 25 May 2011
Nice!
10 under the ben entered for next year. Mixed trio.Team 2 NoNads and a baw hair!![]()
Sorry for the typical answer, but I really would go second hand if I were you.
The spec is pretty below par.
Got to agree with the above, a £1000 seems crazy for such bike. Second hand at £1k would see a really good bike.
Or even something cheaper would have a similar spec.
If you want cheap then use a 20" inner tube cut open and a sealant of your choice (I like Joe's no flats). You can use a normal tyre but UST ones are much easier to seal and have much tougher sidewalls.
need some advice about tubeless conversion
currently have mavic xm317 rims (not UST i think) and maxxis highrollers with inner tube
if i go tubeless what kit do i need and do i need special UST tyres?
thanks for any info
Well that kinda sucks, lol! I should have emphasised that when my friend found it, he was saying it's a decent spec for the C2W price which is £600.
2 things though, I don't have ready cash to go and spend a grand, or even a few hundred quid on a bike. I know I could get something much better with cash in my pocket but as it's going through C2W, i'll get it for £580 and they'll take about £50/month from my salary for 12 months.
