- 8 Jan 2012
Hi all
Would appreciate a little help
I have a corsair HX850 currently and am planning a new. Hold so thought I would replace the PSU as well
How good is this PSU
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-EA&groupid=701&catid=123&subcat=2390
I will most likely be running has well 4770k clocked to max I can with sli evga gtx 780's clocked to max all will neon a custom water loop. Would you recommend I upgrade to this PSU if not what would you recommend?
Thanks
Thanks
