*** Nexus 5 THE Official Thread ***
Dashclock always displays in a minimalistic form on the lock screen (there's probably a way to override this though), but on the home screen (I'm using Nova launcher, hence the lack of transparent status bar and control keys) it will always show full-size if you allocated it enough space.
I'm using an 8x5 grid on the homescreen, with Dashclock resized to fill up the entire home screen (minus the dock).
K, tried to kill it today.. and finally did it! bOOM.. this is above my normal usage of - 2.5-3hrs/screenon/day but I just wanted to see where it dies..
~1hr youtube
~30mins on vine
~30mins music
+ camera
+ app testing etc
and the rest is browsing and standby with wifi on all day
this is on faux kernel
oh and for those that want lower density screen on your N5(imo stock is way to high for this resolution)
example -;
you'll need ROOT but do -;
download -; https://play.google.com/store/apps/details?id=com.jrummy.liberty.toolbox&hl=en
open
navigate to performance
click build.prop editor
find "ro.sf.lcd_density"
change from 480 to 380(if you want the same as my example screenshot)
allow the app to reboot the phone..
TADAAA...
Which recovery is most reliable right now? TWRP?
**EDIT** Also, I don't see where this Faux kernel is? Someone have a link? Thanks.
example -;
open
TADAAA...
Cheers for that mate set it to 400 and it's much nicer!
i getting no issues with battery on this device am 1 day 8hrs in and still on 30%, using it about the same as I have any phone.
