- 29 Jul 2013
As above, thanks guys!
I've used bay res for the last 2 builds and both been spot on, it's more down to personnal taste and if you can fit one in your case imo. The tube res are great for a build with not so much room.
Depends on the res you get some come with the pump in them others the pumps mount straight onto the back of the res.
If you have a separate tube res I see others mounting the pump on a cushioned sound absorbent base which you obviously can't do with a bay res/pump combo.
Is that a problem or are the latest bay res/pump combos quiet enough these days?
Thanks for the response.
Two completely opposing views not sure what to make of that tbh.
