** The Official Call of Duty: Ghosts (CoD 2013) thread ***
Looks like playing cod in the US is a completely different experience than in Europe. Wonder if the pro players would be so good in the UK
You should try playing in New Zealand, I used to get 20-30ms ping in the UK, lucky to get 150ms here. On the upside I don't play games half as much!
Hard at work on the next game :p
Yeah probably. I've had 2 updates so far and I've literally no idea what they've done. Treyarch always gave us info on what's been done whereas IW don't let us know anything.
Also after having some idiot last night playing a Boeing HDMI spec video during the game there is no option to mute people in game.
Idiots like that are the reason I have my chat set to friends only.
Spawning directly infront of the bad guy and getting murdered instantly is awesome too.
Happens too often in this game. I had it happen on Overlord which is a HUGE map. Spawning is definitely my single biggest issue with this game. Even the OP snipers wouldn't bother me if I wasn't actually spawning in front of them.
lulwut?
You do know that the engine runs independently from the rendering right? e.g. Well known games like CSS with their underlying server "tick" rates and Street Fighter with a fixed 60hz engine rate regardless of the frame rate.
http://developer.valvesoftware.com/...asic_Architecture_of_a_Client_.2F_Server_Game
Render Scene is part of the client frame loop.
1. Sample clock to find start time
2. Sample user input (mouse, keyboard, joystick)
3. Package up and send movement command using simulation time
4. Read any packets from the server from the network system
5. Use packets to determine visible objects and their state
6. Render Scene
7. Sample clock to find end time
8. End time minus start time is the simulation time for the next frame
Each time the client makes a full pass through this loop, the "frametime" is used for determining how much simulation is needed on the next frame. If your framerate is totally constant then frametime will be a correct measure.
Had my first enjoyable few games last night and do you know what i was doing???
Sniping and being one of those annoying campers/stealthy moving with all the stealth perks. I was getting 30/5 kill/death scores.
I only play Hardcore though, unless soulja invites me to his games.
Wow, from reading around it seems like this is a totally hacked mess on the PS3.
People hosting all sorts of lobbies with everything unlocked, 2 billion squad points, the lot.
edit: seems there are also infected xbox lobbies too.
