Same but my U2410s instead...![]()
Dammit they've got me measuring up my desk for duel screens now
MW
I had the Dell, RMA'd it due to terrible backlight bleed. The 970D I have now is in a different class, probably the best thing I've ever bought for my PC, it gives me great pleasure now to use my rig, it's a fabulous screen. The 971 or 970 would be great, I have no light issues so the glass screen 970 IMO is better for me, and looks lovely.What makes this monitor better then a Dell UltraSharp U2713HM ??
Would there be any good reasons for me to upgrade from my U2713HM to one of these..
Could that even be classed as an upgrade![]()
I just upgrade from the very same monitor to the 970D. Two words; do it.Damn wish I hadn't seen this thread, I've got to decide whether to upgrade my 4 y/o HP LP2475w now
MW
Gibbo - Any chance the 970D could magically appear at the same price as the 971D.....please?!!
Would be a dealbreaker for me. At the current price, although it's good, it's a wallet breaker!
I'm weak, just bought one![]()
MW
I'm gonna resist... for now...
I don't need this, I don't need this, I don't need this (rinse and repeat)...
Mine came with a Display Port cable and a Dual Link DVI cable too.
Eulogy you could have mentioned this as well.
WARNING YOU WILL NEED A UK --> 2 Metre Figure 8 Power Cable UK Plug.![]()
About the UK cable? I mentioned that in the other thread which was done to death, I was responding to the question about the Display Port cable why would I bring that up?
By the way apparently some people found the UK cable at the bottom of the box under the polystyrene:
http://forums.overclockers.co.uk/showpost.php?p=25266475&postcount=17
The power cable is indeed under the bottom packaging.
So now i have this thing how do i get the 1440 to work without going out shopping again?
I have the 7990 with the mini-display ports,a mini display port to dvi adaptor that came with the card and various hdmi dvi display port cables.Only thing i dont have is a mini display port to display port cable....Works fine at 1080 with the mini adaptor and dvi. but cant select any higher. Do i have to have the mini to normal displayport to get the 1440?
Damn... just had to go on a conf call... had the monitor in my basket all ready to push the button once I had checked my bank account... call finished and the monitor had gone up £100.
Oh well.. its there for someone else now... I can't afford the extra, great monitor or not!
I'll find an alternative elsewhere ('cos most of them are cheaper elsewhere before you ask).. shame.
