Instead of Winnats, anyone fancy a trip to Columbia?
http://www.strava.com/segments/alto-de-letras-completo-desde-mariquita-5608251
Blimey. No wonder your man Quintana's handy on the climbs.
I'm 5'10 ride a 54 and it's an excellent fit. Cervelo's geo is based all around stack and reach.
Hit me. Can start from either Manchester (or Chapel-enLe-Frith) or Sheffield, or maybe Chesterfield.
Heck I'll be driving up so can start anywhere.
so guys any advice on what to do with my bike?
alu frame
carbon fork
fine wheelset
just the groupo is a turd..
should I buy a new groupo or get a new bike? the only thing I don't like about current bike is mudguard clearance(none) the rest I love..
If the bike fits you well, then I see no reason not to sling a 105/veloce level group at it. I'd not go any higher though...
I do have long arms tho so the reach is not a problem.it shouldn't fit me.. its 57/58 frame and I'm 5'9ish closer to 5'10.. but I find it comfyI do have long arms tho so the reach is not a problem.
I was thinking that.. but a full 105 groupo is around 350-400.. I'd love campognolo tho! or SRAM.. hmm need to do more research
You ride the bike, not the fitting manual
it might be worth changing the stem and seatpost etc, they are generally really heavy on a cheap bike
What's your budget?
Looks good, is that the "easy" route up Winnats?
Uh quite happy to say I would not be able to do that.
http://www.cyclinginquisition.com/search?q=letras
