- 5 Feb 2009
Okay. We moved into our new house about a week ago, and soon found that the previous occupants had most helpfully cut the TV aerial cable extremely close to the wall. Thanks guys!
You can see how close it's been cut, and how little cable there is to play with in the attached picture:
There's not enough space to add a standard male coaxial connector. All I've been able to do so far is strip back a bit of cable and attach the inner part of the coax connector and connect it to our freeview box via a female-female connector and a short coax extension cable.
Obviously, this is far from ideal and it's a very delicate connection. Look at it funny and it comes loose. Unsurprisingly. My wife is less than happy with this piece of my handiwork...
Is there anything I can do other than go through the faff of having to drill through the (extremely thick) external wall and thread the cable through where there'll be more to play with? As you can see it comes in at a corner, so I couldn't fit a wall plate either, I don't think. Are any of the various type of cable repair kits able to do anything with such a tiny bit of cable?
Any advice would be most gratefully received.
Cheers.
Cheers.
