- 29 Jul 2011
- Hamburg
Hello Folks!
Ive had the Sapphire 290 for just over 7 days now and beginning to think that the card has a fault. Before I decide to RMA I wanted to ask you if you can confirm my concern.
The problem that I have is the card running on high temps in idle/ 2D usage. Right now I am running Firefox, YouTube, Microsoft Office and Adobe Dreamweaver with two screens. With MSI Afterburner on the card has a temperature of 80c. To note, the PC has been on all day. Often the card remains between 48c - 55c. When I just leave the PC on but have nothing running, the card might go down and idle at 35c. Ive hardly tried the card under performance yet, I played Borderlands 2 the other day and it reached about 85c.
I have not oc'd the card, neither played around with CCC. Ive installed the latest drivers, that actually gave a slight improvement. However, I have noticed in CCC that the card often just sticks at 939mhz GPU clock. The memory clock never changes from 1250mhz. I have experienced 3-4 BSOD since owning this card.
Iv'e done a clean install of the drivers. Ive got a good airflow in the case (6 fans). Ive updated my BIOS. My previous card was a 6950 and never encountered a problem like this. I have regulated the fan speed manually in Afterburner to 35-40% however the card still goes up to 70c.
Here are some screens of the current state now:
My System:
i5 2500 (stock)
MSI Z68A
8GB ram
1 HDD
Win 7 64bit ultimate sp1
Antec Truepower 650
Anyone have an idea what's going on? This surely cannot be normal? Fellow 290 owners, what are your idle temps? Should I RMA the card?
Any advice is most appreciated!
My System:
i5 2500 (stock)
MSI Z68A
8GB ram
1 HDD
Antec Truepower 650
