PC & Monitor £800
11 Nov 2013
Hi experts,
I need to replace my 7 year old PC, its had a few upgrades but think its now finally time to bite the bullet again and replace.
New PC will be used 90% for gaming - FPS and RPG games with a focus on potential new titles, nothing specific.
Things that may (or some may not) be of use from the old PC:
6.1 surround speakers
PSU - Tagan 480W
2 x Internal HDD - HDS 250GB SATA-300 / 3.5" / 7200 rpm
1 x External USB 2TB drive
Thermaltake Tsunami dream case
Brand new dvd drive
Windows 8
Standard USB Keyboard and Optical USB Mouse (I would replace if it really justified it never really looked at the nice ones)
My monitor is small compared to whats on the market now so that needs replacing, 24" widescreen would be nice.
Budget I would like to be £800 ish with a motherboard that give me some kind of room to flex components up in 2-3 years time when it starts to struggle again so can get some more life out of it.
It will be a self build, I have never overclocked but sure I can pick up the how to's from these forums if your recommend to do so with the suggested components.
Hope that covers all the bases.
Thanks in advance.
Thanks for the swift reply RJC.
Would you recommend to overclock that setup or leave it as defaults ?
Bin my PSU then and re-use the other bits, HDD's as storage. SSD you put as the O/S disk ?
No probs :)
Pretty much, SSD for the operating system and the others for storage and other programs which you won't want only your SSD.
Put a new PSU in there due to the age of yours and power output, overclock straight away :D
what case would you recommend as a replacement ? if its negligible cost ill find the extra
sorry didn't read the end of the post - my boy was attacking the keyboard :)
Thanks Binnsy for the extra option.
That Toshiba SSD you mentioned looks faster read/write speads and cheaper than the Samsung one, is there a quality difference or am I reading the figures wrong.
Also the PSU at 100w less would save me a few quid, do I really need the extra 100w in this setup, I would be running 1 x SSD, 2 x SATA and 1 x DVD drives.
Would like to hear your thoughts, thanks
