Is the 318D sport a lot less of a car than the 320D sport F30?
What's the major difference between the E90 and F30?
[TW]Fox;25255762 said:It is the same car with the same engine in a lower power form.
Do note that an F30 Sport is not the same as your E46 Sport was. Your E46 Sport was the top trim level with bodykit, etc etc. The F30 Sport isn't like this, the equivilent of your E46 Sport is the F30 M Sport.
They are completely different cars on different platforms.
[TW]Fox;25255919 said:The MPG is very likely as near as makes no difference the same.
Only pick a 318d if it is usefully cheaper than a 320d or if it allows you to buy a much higher specification car.
Also, make sure you chose an Automatic F30. The 8 speed autobox is absolutely fantastic and makes the drive so much better than the frustrating experience a 2 litre diesel with a manual gearbox can often be.
Yeah...I have the auto now I would definetly want an Auto in the future does the M sport have toggle switches for Steptronic?
[TW]Fox;25256110 said:Paddles come when you specify Sports Auto Transmission. It is a £150 option above the regilar Auto Transmission. Some people tick it, some don't. If paddles are important to you, look for a car with that option.
Not sure if your thinking of keeping the e46 nor doing the rust yourself or not, but, if you are, this months Car Mechanics Magazine has a step by step wing removal & rust repair article on their project e46 320d...
Just been reading it in Tesco - it made me think of this thread!![]()
Contact either a crash repair place or a restoration place - the arches are nothing scary compared to damaged or classic cars.Afternoon easy,
thanks for the images supplied. Looking at the rear arches we wouldn’t really get involved with them. The only real way to cure perforation is to cut it out and weld in fresh metal. The cost to replace the front wings if you supplied them would be £608.64inc.
That is incredibly cheap for the work, make sure that they are going to cut out and weld in new repair sections on the rear wings, instead of just filling it with filler.
As above that's almost suspiciously low. You're talking minimum 120 a panel and if he is talking about doing the doors ( which makes sense given the colour ) you are getting 6 panels done....that's before cutting out and welding new section in.
