*** The Official Playstation 4 (PS4) Thread ***
Can't believe the console wobbles like that.
Especially after the **** about the xb1 beingbalanced lol.
A design choice? Jesus Christ. More like a design oversight.
If this was xb1 everyone woul be like hyenas.
I know its crazy. I mean, I love poking my games console all day long to see if it sits still. Totally affects everything. Totally.
I'm not saying it's that bad but it will annoy me knowing it does it.
Hopefully they sort it out by next year when I get one.
But there's nothing to sort out. It won't cause vibration or shake when the disk spins. It doesn't affect anything so there is nothing to fix.
Its designed that way to look better then its stood vertically, otherwise you will have a bit of plastic sticking out the side.
Jesus Christ!
What are you going to do if someone looks at you when you buy a XB1? Slit their throat for daring to glance at your precious ffs :D
Marvel looks really tempting. I absolutely loved Ultimate Alliance 1 to pieces... I wonder if it can live up to that game. It's got a 9 on IGN, so looks promising.
Its a Streaming service, it still needs to process the controls but the game is being streamed from a PS4 to your Vita screen, its also downscaled.
AFAIK its a bit like onlive gaming, where the backend is processing the game, your screen is showing the stream with the device handling the controls.
so basically the Vita is showing the image being streamed and handling the controls for the game. Some processing is done on the Vita such as controls, but the game itself is being processed and downscaled via the PS4.
Exactly...I'm not denying it's an awesome feature, it's great to have the feature plus over wifi opens up great opportunities when away from home (those will be refined eventually) and simply the fact you can game anywhere in your house is great.
It's pretty much a stream which is the same as the Wii U like Broken Hope said, just over WiFi.
Anyways...rather underwhelming review scores to be honest, launch etc I know, but I just hope people are picking up Battlefield 4 which I can assure is awesome (PC version here so you will get to enjoy the proper experience on consoles this time).
so it is missing a rubber foot but its been designed like this.. hmm seems a bit odd, but if it doesn't affect the way the console operates or doesn't cause excessive vibrations then ok fine. not like I sit there pushing down on my games consoles...
just seems to be an odd design choice IMO
Initial reviews of the hardware and game are a bit disappointing. Pretty tempted to cancel my preorder and wait for the inevitable Infamous bundle as that looks epic and if there are any hardware issues then they should have surfaced by then as well.
The downside to Sony focusing so much more on being a games console rather than XB1's media center approach is that until some great games arrive it feels a bit like having a supercar but only being allowed to fetch the groceries.
