Hi there
As our sales of the Apple AMD cards has being pretty good, were also offering the Apple flagship 27" Thunderbolt monitor too.
Please bear in mind our price includes an additional 2yr AppleCare warranty, giving a total of 3 years, as standard Apple only give you one year warranty and yes they have the small print to make it legal too.
Apple MC914B/A 27" Professional Thunderbolt Widescreen LED Monitor with 3yr Applecare Warranty (MF224M/A) @ £899.99 inc VAT
Thunderbolt I/O technology lets you move data between your devices and your computer with unprecedented speed. With two channels of 10-Gbps throughput in both directions, it’s up to 20 times faster than USB 2.0 and up to 12 times faster than FireWire 800. And it allows you to connect as many as six devices through a single, compact port.
With just one cable, connect any Thunderbolt-enabled Mac and get 27 inches of high-resolution screen space, high-quality audio, a FaceTime HD camera, FireWire 800 and Gigabit Ethernet ports — and a Thunderbolt port you can use to daisy-chain additional high-performance peripherals such as hard drives and video capture devices.
The Thunderbolt Display includes a MagSafe connector that powers and charges your MacBook Pro or MacBook Air.1 The connector sits on your desk, ready and waiting. No need to unwind the cord to the power adaptor that came with your notebook. Leave it exactly where it is, in your bag.
Connect your Thunderbolt-enabled Mac to the Thunderbolt Display for a panoramic viewing experience unlike any other. This huge 27-inch glossy widescreen display features a cinematic 16:9 aspect ratio and an astonishing 2560-by-1440 resolution. That gives you more room to work with apps on your MacBook Air or MacBook Pro. And a worthy desktop companion to your iMac or Mac mini.
Full brightness with no waiting. That’s the big advantage of LED backlight technology. Unlike most displays that take time to warm up before they reach maximum brightness, an LED-backlit display is instantly on and uniformly bright. LED backlighting also gives you greater control over screen brightness. So you can tune the Thunderbolt Display to suit the ambient light in even the dimmest room.
Thunderbolt-enabled Macs, including the current generations of MacBook Air, MacBook Pro, Mac mini, and iMac are fully compatible with the Apple Thunderbolt Display. Customers with Macs that only support Mini DisplayPort output, such as the Mac Pro and MacBook, as well as previous generations of MacBook Pro, MacBook Air, Mac mini and iMac can use the 27-inch LED Cinema Display.
Features:-
- Built-in FaceTime HD camera with microphone
- Built-in 2.1 speaker system
- Colours: 16.7 million
- Viewing angle: 178° horizontal; 178° vertical
- Brightness: 330 cd/m2
- Contrast ratio: 1000:1
- Kensington security slot
- Energy saver mode: 1W or less
- Compatible with VESA Mount Adapter Kit (sold separately)
Specification:-
- Screen size: 27 inches (diagonal viewable)
- Screen type: TFT Active-Matrix LCD
- Resolution: 2560x1440 pixels
- Color resolution: 16.7 million
- Aspect ratio: 16:9
- Brightness: 375 cd/m2
- Frequency Response: 12 ms
- Size and weight: Height: 49.1 cm (19.35 inches), Width: 65 cm (25.7 inches), Depth: 20.7 cm (8.15 inches) with stand
- Weight: 10.8 kg (23.5 pounds)
- Ports: Three powered USB 2.0 ports, Firewire 800, Gigabit Ethernet port, Kensington lock slot & Thunderbolt
- Camera and Microphone: Built-in FaceTime HD camera with microphone
- Speaker Configuration: 2.1
- VESA Compatibility: Compatible with VESA Mount Adaptor Kit (sold separately)
- GbE Ethernet Firewire 800 WebCam 3xUSB2
- Warranty: 1yr STD Apple Warranty PLUS 2yr Applecare Warranty. (3yr Total) (Applecare 24hr Hotline: 0844 209 0611)
Only £899.99 inc VAT.
ORDER NOW
Features:-
Specification:-
ORDER NOW
