This might be an odd question seeing as I’ve only had the M3 for about a month but there might be an opportunity to put 10k (NZD) on top of mine to get the M5, which is a very good deal out here in NZ (especially for what I paid for the M3). Don’t get me wrong the 3 is a beast and it’s great fun to drive on the weekends.. it feels better than ever after coming back from the Inspection II having the Vanos parts also fitted.
I guess the main question is how much more to run than the M3 is it, roughly in terms of servicing and parts (not fussed about petrol, as it’s just for the weekends). I’m probably more worried about parts breaking and a like for like. E.G the SMG pump on the M3 will be 1.5k or so, is this similar to the M5? I’ve searched for the tyres and brakes and while it’s a lot it’s alright. What about the clutch? I heard they don’t last all that long.. The one is question has also apparently had a vanos upgrade but it’s a UK import which affects resale out here in NZ substantially (there is an irrational fear of salt damage on UK imports). It would be good to know what other bills this beast could potentially throw at me.
If anyone has done this transition or is in the know I’d like to hear from you!
http://www.trademe.co.nz/a.aspx?id=660504583
Cheers
Cheers
