I really must be missing something - out of the box it should be noticably worse than a 690?
How?
+1
Out of the box a GTX 690 will annihilate it.
Meh.
Out of the box a pair of reference GTX760's in SLI will beat a Titan and almost equal a GTX690 in Tomb Raider + Bioshock Infinite and the Titan will claw back just in Metro LL. However factory overclocked GTX760's in SLI will edge out the GTX690.
You have to remember that a GTX690 is based on two under clocked GTX680's, of course it can be overclocked in which case it would pull away from the Mars 760 (depending on how well ASUS beast it up), but out of the box the Mars *should* win.
So Nvidia really are pulling out all the stops to try and stop those AMD sales.
So Nvidia really are pulling out all the stops to try and GET MOAR MONEYZ!.
Nope, Asus will be doing this independently and nothing to do with Nvidia!
39. Score 1967, GPU 690 x 1 @1160/1750, CPU 3960X @5.0, Kaapstad
40. Score 1964, GPU 770 x 2 @1150/1752, CPU 4770k @4.5, Smok3alot
41. Score 1957, GPU 670 x 2 @1267/1228/1876, CPU 4770k @4.5, setter
42. Score 1950, GPU 770 x 2 @1150/1752, CPU 3770k @4.2, RetrogamerX
From the Heaven 4 bench, no GTX 760s but I think the GTX 690 does ok against some of the other NVidia cards.![]()
Those are some nice out of the box scores there![]()
This is a comparison of GTX670 SLI vs GTX690: http://hexus.net/tech/reviews/graphics/39605-nvidia-geforce-gtx-670-sli-vs-the-beasttm/?page=5
It shouldn't really be hard as this is a Mars were talking about, they're the Nvidia equivalent of the Ares, ASUS is going to make sure it's an absolute beast.
So to be clear, we're starting with a clocked 760, adding another to the same card, and then upping the core clock to hit this 690 beating performance out of the box. Is it coming with a custom watercooling loop out of the box too, or a fire extinguisher?
If Asus really wanted to create a monster card they should have used two full fat 780ti cores and a waterblock. The power draw would have been huge but on water it would not matter.
The GTX670 is better than the 760.
I don't understand why they want to use 760 GPUs though.
