**The NEW Tomb Raider Benchmark Thread**
Status
Not open for further replies.
Just found some old ones on imageshack
Some old ones of my Titans @981/1788
3930k @5.1
1080p
Two Titans
At some point I will try and break 270fps but at the moment it is a bit warm in my room.
Just wondering about this one Kaap, I thought the perf gap between a Titan and 780 was roughly 150mhz, how are you're Titans at 981 core hitting 142fps yet my two 780's at 1200mhz core are only hitting 123fps? Granted my memory was only at 1600 vs the 1788 of your titans but I wouldn't have thought that still adds to a 20fps gap?
I think the gap is closer and is around 100Mhz Paul. I would assume that Kaaps are boosting to maybe 1050 or higher and the memory clocks do give a nice boost.
The clocks I quote are the stock 837mhz for a Titan plus whatever I add in Precision X, in this case +144 to give a total of 981mhz. If you were to watch them running in GPUZ they would be boosting much higher to 1175 or 1188mhz. I don't believe in quoting these boost clocks as they are not consistent and would rather use the set clocks which are.
Here is a run I just did on TR with the clocks set to 994/1788 to show the boost clocks. Normally I would not have any of this running as it effects the score a bit.
Just ran this one off using the settings in the post above
4 Titans @994/1788
3930k @5.1
320.18 drivers
269.9fps.:D
1080p
Updated, I think...
There may be some errors or missing entries, but it's 3.27am and you guys are a right pain in the arse with the multiple submissions :p
Ahhh forgot you had boost on top of those clocks!
Was worried my 780's weren't performing as they should :o
Thermal choke cut off still 70c? I did notice my top card fluctuating in core speed the higher the temp went, pesky air coolers :D
Have you tried any of the other overclocking software to see if they work any better than Precision X
Widespread issue?
Sorry hadn't seen these (even though spoken about it in another thread :p)
I tried GPU Tweak Kaap, same result. Throttles the coreV down to stock or near abouts. Hovers over 1.50/1.72 occasionally but rarely ever 1.2v. Think judging by what other users are saying (and merry old GTX owners) it's hitting the power limit quickly. Which for me is really f'ing irritating as my superclocked cards aren't as good as some are getting on the core front. I'm not really a massive fan of GPU flashing either as it's always eventually ended up leaving me with a hole in my foot.
Well apparently my cards memory still had a lot to give :D
EVGA 780 SC @ 1163/1851
2600K @ 4.5
331.65
1920x1080
Status
