- 18 Oct 2013
- Birmingham
pic :
System :
i3770k + h100i
z77 sabertooth
8gb xms2 ram OC'd to 1600mhz
2x 7970 xfx black edition
Ok so I increased the multiplier to 45 to get to 4.5ghz. Set the CPU voltage to 1.23 (had a bluescreen at 1.2) should I try bringing it lower still to bring down my temps?
I've used the AUTO settings on the BIOS for everything except the multiplier, CPU voltage and I turned off EPU.
I did a couple of hours of prime 95 and everything seems to be going smoothly, temps are absolute maxmium 85 (I ran it for a bit longer after those screenies). Is this too high for my current OC? With the standard clocks I get 32 idle 60 load.
The overall package power usage seems fine, I'm happy with what it's producing. I'm just wondering if you can see anything horribly wrong that might send my computer to an early grave.
Note: the Z77 sensors are screwed so the TMPIN4 temperature is unreliable. It sometimes shoots to like 500, so I know it's nonsense.
Should I bother pushing it further? I don't intend to buy a new CPU for a while, and sending this one to it's grave would screw me over for my employment. I also get pretty uncomfortable when I see temps over 80.
Getting fps drops in bf4 from the usual 60 to 45 ish, ultra settings with AA on 2x 100% resolution 1080p. Surely that can't be normal? I'd assume i'd get a solid 60 on my system.
Thanks if you took the time to read this! I'd rather ask than do something stupid and wreck a good machine.
System :
i3770k + h100i
z77 sabertooth
I can't say this will be better 100%, but there is only one way to find out.. that's why we are enthusiasts, we pursue max. performance because we have the time and energy for it
). Gaming temps are always 20-30 lower than Prime. Honestly, your temps are fine now, but they can be fine-tuned if you like.
