1st time build HELP
13 Nov 2013
Hi there... Can any of you help me to build a tower?
i5 or i7 3.40ghz or more
500gb SSD
Graphic card 3gb or more
These i defo want these in my rig
looking to build a gaming one my budget is £1000-1200, will be play games like d3/ dota 2/ BF3/ TR/ Walking dea and other
Dont need a mouse/ keyboard/ monitor/ speakers
THANKS
Do you require an operating system ?
Do you want the option to run 2 cards ?
Stulids build above is very nice for a single card setup.
I dont want and extra hhd only want to use he ssd or do you need one? And yes i need a windows 7 utl too, forgote to put it down and dont want 2 cards 1 good one instead of 2 ok cards
You don't need one..
Most people use a small-ish 120/250GB SSD and a 1TB HArd drive for file storage..
Doing it that way could save you a £100 or so..
Though if your happy with a 500Gb SSD, drop the HDD from stulids spec and add windows 7/8/8.1.. :)
if u want a gaming comp i would advice getting a smaller SSD, and a 1TB hard drive and a better grahic card , no really need for a 500gb on ur budget , its just stupid really
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99 inc VAT
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) HDD £76.99 inc VAT
Is that ok? And what graphic instead? And my friend has got a spare OS
Boom great build, i however would wiat like 3 more weeks for the 290 cards to come out so that the noise and heat gets better but other than that good shizzle
There are as loud as people think they are.
The recent Catalyst Beta driver increased the fan speed to 47% from 40.
But the bang per buck is epic.
OcUK 24x DVD±RW SATA ReWriter £19.99
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache HDD £47.99
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic £79.99
CM Storm Scout II Advanced Gaming Case £94.99
Corsair Dominator GT 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit with DHX Pro Connector £89.99
Antec High Current Gamer 750W Modular '80 Plus Bronze' Power Supply £99.95
Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £107.99
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor £179.99
MSI Geforce GTX 770 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £311.99
Enermax T40-VD Vegas CPU Cooler £34.99
£1078.36
this is what i done what you think? anything i should avoid?
£1078.36
The gtx770 ;)
You don't need a separate CPU cooler if you're buying from here, if buying a large CPU air cooler need to make sure it doesn't clash with the ram if its not low profile.
£1078.36
I already said the D3HP comes with a free heatsink so why add another?
The D3HP doesnt support SLI so you dont need a 750W PSU.
