- 25 Nov 2009
Hello chaps,
I recently bought an R53 from a specialist dealer, it came with 12 months MOT and 6 months warranty (private offered by the dealer and his garage)
2 months have passed... I hit a pothole doing about 3mph down a country lane in heavy rain, since then the car has made a grinding metal/metal noise coming from the front O/S. I had already ordered a set of discs and pads as Opie oils had 15% off Brembo so decided I'd check out the noise whilst fitting these (they were an advisory on the MOT 2 months prior)
As it turns out, the wheel bearing has collapsed and the rear lower wishbone bush has torn. A new bearing will be ~£115 and a pair of wishbone bushes will be £52 but could be a good days work by the time I've dropped the subframe. So my question is A) is the dealer likely to fix it as surely the wheel bearing and bush couldn't be that bad with an MOT only 2 months ago!
And B) what are my chances of claiming anything from the council for the damage?
I have a good idea what the consensus may be and TBH I don't really object to doing the work (any tips on changing a wheel bearing and wishbone bush?) but if you don't ask you don't get.
Thoughts on this much appreciated
