Apologies - I have in the past contributed and even moderated specialist forums, and I know how frustrating these sorts of questions can be. They can be very subjective, and often best dealt with through personal research rather than relying on other people's opinions.
That said, there is just so much information out there about graphics cards that I am drowning!
I would greatly appreciate the answers to some questions of a less subjective nature, to assist me with my selection, though if you want to express an opinion as to which is the best of the cards, I'd be happy to listen!
I am looking to purchase two cards, and have set myself a limit of £240 per card. This gives me the option of a couple of GTX 770 cards, but limited to 2GB memory, or a selection of GTX 760 cards, a couple of which have 4GB of memory. There are also different cooling methods, and different clock speeds.
These are the cards that I have been able to narrow my choice down to from the original list of 15 or so that I started with: -
GTX 760
1. EVGA GeForce GTX 760 SC 2048MB GDDR5
Core: 1072MHz, Memory: 2048MB 6008MHz GDDR5, Stream Processors: 1152, Shader Clock: 2144MHz, SLI Ready, PhysX/CUDA Enabled, 3 Years Warranty. Induction fan.
2. Gainward GeForce GTX 760 Phantom 4096MB GDDR5
Core: 1072MHz, Memory: 4096MB 6200MHz GDDR5, Stream Processors: 1152, Shader Clock: 2170MHz, SLI Ready, PhysX/CUDA Enabled, 2 Years Warranty. Dual fans and radiator?
3. Gigabyte GeForce GTX 760 WindForce 3x OC 4096MB GDDR5
Core: 1085MHz, Memory: 4096MB 6008MHz GDDR5, Stream Processors: 1152, Shader Clock: 2170MHz, SLI Ready, PhysX/CUDA Enabled, 3 Years Warranty. Triple fan.
GTX 770
1. OcUK Geforce GTX 770 2048MB GDDR5
Core: 1046MHz, Memory: 2048MB 7010MHz GDDR5, Stream Processors: 1536, Shader Clock: 2220MHz, SLI Ready, PhysX/CUDA Enabled, 3 Years Warranty. Induction fan.
2. Gainward GeForce GTX 770 2048MB GDDR5
Core: 1046MHz, Memory: 2048MB 7010MHz GDDR5, Stream Processors: 1536, Shader Clock: 2220MHz, SLI Ready, PhysX/CUDA Enabled, 2 Years Warranty. Triple fan.
So my queries are as follows: -
GTX 770 can obviously be presumed to be better than GTX 760, with more stream processors, faster RAM and faster shading, but does the 770 still hold the advantage if the 760 has twice the RAM?
Am I right in thinking that the induction fan system is better at expelling heat from the case, whereas normal fans will push the heat in to the case? Even if this is the case, would the (presumably greater) cooling power of triple fans still hold an advantage?
The Gainward GTX 760 has faster RAM, but only dual fans - would the faster RAM be more of an advantage than the presumably greater cooling power of the Gigabyte's triple fan?
I would greatly appreciate a quick response, as a couple of these cards are on offer at the moment.
Many thanks
SteveW
GTX 760
GTX 770
Many thanks
SteveW
